3bar with ALKY question...
turbopat
I’m installing my new system from Cal, I’ve run into a little bit of a snag with the map sensor. I have Alky and I have it run to my 3bar under the hood. The new Casper’s harness states that I need to hook my map sensor up to it. There’s only enough room to run the map sensor in the car..... Do I just run an extension wire from the alcohol green wire to inside the cabin and also run the vacuum line inside the cabin? How has everybody else done this?
You can either splice in a second harness to the current map harness or run a second map dedicated to the xfi with it's own harness. I run a 3.5 bar map for the xfi and a 3 bar on separate harnesses for alky.
Will I need to t the xfi map to the same vacuum line?
