SignUp Now!They are Comp stainless self aligning stainless steel big fulcrum rockers for a SBC...mucho tweaking to make them fit.
Nice job on the rockers. I did that back in 1992 when I was running TA heads in my GN. You will enjoy not breaking stock rocker arms with the increased spring pressures. I also added an extra bolt hole on the stock 4.1 block and to the heads for added clamping on the easily lifted TA heads. Good Luck
The extra bolts would be the 3 upper bolts as with stage 2 blocks. They are located right between the rocker pedestals and drilled straight thru the heads. I used one size smaller head bolts as there is not much deck space on the stock 4.1 for drilling the holes and torque them to 40 ft/lbs. It was much better than pinning the heads. It was a very trick setup up, done some 15+ years ago.
I ended up using them on the stock 4.1 as I was in a rush to get a motor together. I have horrible looking pictures somewhere, but we didnt have digital cameras back then. If I find them, I will scan them and post.....No, I am talking about turbo ta heads. I was one of a few using them back then. They were modified for the extra bolt holes to use on a stage block as the ta heads lift under high boost and any detonation.
can you post any pic of port work on the heads ,thats if they were ported...:smile:
That would put you rite through a water passage. Look at the pixs of the deck surface. You would have to add meat, and the only place without water passages would be between the pushrods. Then you couldnt have proper clamping to the deck.
The problem with the TTA heads is the very long 2 center head bolts. And a set of nice studs solves this.
See if I can find a junk TTA head and drill through the deck see if it hits water.
All of them have shaft rockers originally, the TTA heads, as far as I know, didn't diviate that far from the GN heads. Messing with GN heads on a stock TTA short block would lower your compression aswell. For me I'd almost like to go the other way since my pistons volumed a bit high but I've got enough troubles as it is with stuff fitting and like you pointed out, the less rolled GN heads flow a bit better than the TTA heads I do believe.If you had a GN why would you use a TTA head in the first place. I'd bet there would be no noticable difference as far as flow between GN head and TTA head ported or not. Plus you have a shaft rocker setup on the GN head. I'm sorry I don't understand the point.
Michael
