ok heres the deal new 4.1 was running good for the for the first couple hundred k now the vac gauge is low between 5 an 10 used to be 17 20. it swings at idle 5-10 , no exhaust leaks. or vac leaks
that I found, plugs looks similar, put theres a noticeable loss of power now. brought it in to the mech says 4 an 6 aren't working properly?
im thinking camshaft?
any advice or tips I should look at/
thanks
thanks
