SignUp Now!the 471s are hyper cast pistons-can be brittle , I have a forged set of Ross 4.00" pistons for a stroker combo for $300. Shipped that I'm not going to be using
Does anyone have a part # or manufacturer that makes a 4 inch bore piston for the 4.1 block?![]()
Let's try this again. What's a striker combo? And what I've been thinking is there a simple replacement piston that's for an engine with a 4" bore that would be able to go into the 4.1 bored to 4"? I was thinking that I would use a 3.0 rod (6.33") instead of the stock rod. Kinda like using a 6" rod in a 350 chevy. Increasing power levels and allowing a different rotating mass.
Nick the specs on the Ross pistons are: 4.00" bore , 1.205 comp height , .927 pin dia , 2.500" pin length , 100M # 67045A .The pin does not go into the bottom ringland. Just pistons- no pins or locks.
