Assuming both pumps are ok, like posted previously, it's the lines. The attached chart shows you should have another 20 psi or so of fuel pressure. The plot shows the typical performance of a double pumper along with six of 120 #/hr injectors (corrected for the increased density of E85, i.e. 120 pph gas injectors become 112 pph of E85). These curves do not take into consideration losses from lines, connections, etc. It shows that you should have adequate flow and pressure to 120 gph and 70 psi respectively (with 20 psi boost, 13.5 volts, 100% dc). Even at only 12 volts of pump voltage, you should still be good to 60 psi. So obviously something is up.
