Guys I cant seem to get my car to run 20# of boost with e-85 and 120# injectors my power logger says its running lean 11.5 and the duty cycle is 100% at 20# of boost I am using a TT 6.0 chip that has fuel correction and is adding the max 33% more fuel at WOT lucky I am also running Alky injection with Methenol I am running a R/A double pump thru stock fuel lines and a champion fuel rail. is this possible that the 120# are not big enough to support my motor at 20# ??? or is it a fuel volume problem due to the stock lines ? also I noticed that the inlet fitting used on the Champion rail might be to small .. any advice ....
