4.1 stroker motor owners
Sleeper
Looking to see what setups you are running.
Please list build info:
Crank stroke
Rod size
Piston make
Piston compression height
Deck height
Head gasket
Quench
When we build an engine, it is done to the customer's requirements and ultimate use.
We order the parts and do the machining to match. Since blocks and other parts vary, the exact specs are not determined at the beginning of the process, but as it progresses.
To answer your request, you will have to meet with the machine shop to plan your build, or deal with an experienced shop that has done this successfully in the past. :)
3.625 stroke
6.3 rod
Diamond pistons
1.39 compression height
9.515 deck height
.051 head gasket
Quench: piston is .010 in the hole, so .061 with a .051 gasket
What do the majority of your customers use, or what do you recommend to beef the bottom end? A girdle or steel caps for the center 2 mains?
