If we increase the size of the valves,open and close them faster and farther,increase the diameter of the cylinders,and increase the stroke, air moves through the motor with less effort. If we do all of these things and nothing else,the boost will be lower but the motor will still be getting the same amount of air or more and will make the same amount of power or more. If I wanted to see 30 lbs of boost with my 273 291,I'd have to use a much larger turbo. It would probably have to be large enough to move an amount of air that would support 900 -1,000 hp. You can expect either block to break at these power levels.
Boost pressure is a measurement of the air that is not entering the combustion chambers. It is easier to get more air into a bigger motor with less effort,so comparing a larger and smaller motor's boost numbers is an apples to oranges comparison. The smaller motor has to run more boost to make the same power as the larger motor. To say that the larger motor is less reliable at higher boost is not a bad thing because it doesn't have to run as much to make the same power as the smaller motor and everything that happens with the bigger motor will happen faster while producing more of the most important thing (torque).
