4" mass air pipe with Z06 sensor
Yes. Im not sure about early versions though. Call Full Throttle. They have a high customer service level and will be able to help.
Can this be used with the regular Translator?
I believe he posted in another thread that you could use it with the regular translator but if it's an older one you would need an updated chip. Like others have stated if you call Mike you'll know for sure.
Regular Translator
Mike said the new pipe can be used with the regular Translator. :D The new ones are fine and the older ones will require a chip update.
