$400 2000 GSE Regal
wingwang
Hi everyone I'm new on here. I just got the Regal. I was wondering what the factory boost is supposed to be? As of right now it pushes 9.1. Not sure if any mods were done to the car. Planning on doing this biotch up!!!:cool:
you paid 400 for a GSE? if so damn. I miss my GS and my GTP.
stock boost is 10( or under) If im not mistake.
Yes, $400 for my car it has minor damage and missing some interior parts.It was hit by a drunk driver in rear driverside door and quater panel. It runs and drives fine getting on the parkway and flooring it, it hits 9.1 lb I think I'm going to do 2 1/2 start pipes with high flow cat and header. What order do you suggest I start?
your cat is fine, save your money there and get a U bend delete, take a look for yourself at the ****ty exhaust pipe where your O2 sensor is at. Any exhaust shop will do it for you cheap. That alone frees up 5hp.
Get a better muffler,
Air intake
tune up(premo part)
you have alot of vendors for this type of motor:cool: It all depends what your goals are.
Add a oil cap breather.
Check out Zzperformane.com I have sent all my stuff to them piece by piece I own a 98 gs and running in low to mid 10's... Best 3800 specialist around check them out... Very resonableon prices
