S
steve h
Guest
Help. I just rebuilt a 400 turbo for my gn using a Hipster brake. Got it all done and no reverse or t-brake. With it on stands it will turn the tires in reverse but doen't have enough to move the car.
The brake will hold in 1st untill you give it some gas then it goes forward. I thought maybe i had to much travel on the rear band so i changed apply pins. No luck I air checked everything as i assembled the trans. I haven't checked line pressure yet . It does go into forward gears hard like it has plenty of pressure. Forward gears work fine. I've done 400's with tci brakes before with no problems. Any ideas? Internal problem or something fixable in car? Thanks Steve
