I need some tech help. I have a 1979 Regal, nothing special just a normal Regal with a normally asperated 231. I want to do a 455, wondering what motor mounts and pully brackets I need. And also where i can get headers cheap, only place I know that even has any is TA Performance.
What year is the 455. If its a 69ish thru 72 its an easy swap, all you gotta do is drill new holes for the motor mounts (if you use an existing hole thats not perfectly aligned, the motor maybe torqued at an angle and chew up u-joints). the engine brackets will work on any similar generation just let me no what year the motor is and ill help you out. I did a similar swap with an olds 350 in a 86 g body and its now my daily driver. I hope this helps and any other questions just let me know and ill help you out as much...and by the way that cars gonna haul a$$
