SignUp Now!KWIKR 1 said:Let me know what size you have..obvious it must be working for you .. i have 2 x 12 an bungs welded into pan . should be good to go . thanks .
Make sure if you return into the side of the pan you put some kind of baffle there to keep the oil from spraying down the crank. You should be find with -4s, just make sure your returns are free flowing.
Sounds like a good plan to me. 1/2" should feed 2 -4's well.
