4l60e
Breaky
Has problems with my 4L60E. It slide sometimes of the schlaten of 2 in 3 course. Have you an idea? Thanks
i think your saying it slip's on the 2/3 shift. this can happen when the 3rd gear clutch's are going bad. or maybe the 2nd gear band is starting to burn. also in side of the valvebody is the accumulator valve. i like to put a heavy duty spring in place of the stock. for harder shift's. or with a hi-stall converter. you can block this valve for very hard shifts.
