I was told that there are two different 4L80E transmissions; the newer ones are more desirable. What are the good years? Is it 97 and up? I was also told that you can I D them by looking at the oil cooling lines. What should I look for? Cooler lines side by side? Or cooler line from two different locations?
Also if you have XFI, do you still need another computer to control the transmission.
Prasad
Prasad
