TexasT
Texas, Where are you from
- Sep 10, 2002
I have a 99 k2500 suburban about 190k miles, 454/4l80e. Yestrday on the way to work I got off at my exit and the thing started shifting about 25-3500 rpm no matter the throttle position. On the way home the ses light came on still not shifting well. It did finally go into over drive when I was almost getting off the freeway. This am shifted pretty normal until it warmed up. Throwing a po122, scanner sez low voltage tps sensor. Heading over to get a new tps. Is this going to fix this or am I looking to do more and if so what should I look for? TIA
