5.3 24x LS brand new build
hflwyo
Brand new build. Short block just back from machine shop. 5.3 bored .020 new pistons, rings and bearings throughout. Arp rod bolts, timing set bolts, head bolts and crank bolt. Sloppy stage 1 cam with BTR springs. Heads have fresh valve job. All new seals and gaskets. New Melling 10296 oil pump, LS7 lifters and trays, chromoloy pushrods, new timing chain. Rockers have trunion bearing upgrade. Comes with water pump, flywheel, plugs, 160 thermostat, p/s pump and alternator bracket. Located in Columbia, MO. $6,500
Also has sensors and f-body oil pan for clearance issues with most LS swaps.
