5 Wire LS1 Sensor
Razor
Forum tech Advisor
Staff member
Anyone know if the 5 wire LS1 sensor from a 2000 vette be used in conjunction with the translator?
If so..anyone have a pinout?
Thanks guys..
Julio
depends on how old the translator is.
from about version 5, the 85mm sensors are programmed on BASE settings 6, 7, and 8
(7 is richer idle)
(8 is leaner idle)
What version translator do you have?
B
Well.. on the PCB it says rev 1.1 and under that has V-4-1 so its version 4.0 according to the cover??
Will this work? if so, where can I get a pinout of the 5 wire LS1 sensor?.. If not, what LS1 sensor do I have to look for..obviously a three wire..
Thanks...
The version is on the cover.
Version 4 did not support the 85mm MAFs
So you can update to the latest version and get the 85mm MAF adapter cable.
Or buy a different MAF. Any Vette or F-body LS1 sensor up to about 2000/2001 is the right one (3.5" Aluminum body).
Bob
What is involved in getting the update? and how much $$$ :D
Cant I just solder wires to the pins on the sensor saving me some dough?..
Problem is I have the 5 wire sensor... what would be cheaper, to get a different sensor or do the update on the box?
Thanks a million
Ping..ping..anyone out there???
Update for translator..how much????
Mine has settings for a 3.5 MAF already..why update..need DATA>>plez
The 85mm MAF has a different calibration than the 3.5"
it won't run right.
The adapter harness is 20.00 I think, an update to your translator is 35.00
Cheaper? Depends on how much you can find a MAF for.
Bob
I assumme :D these are available from Ramchargers..might you know the part numbers I have to give them? And a good time to call.Ive tried calling last Friday and no one was picking up the phone..
55 sounds cool to me..cheaper than a new MAF 4 sure..well :)
The 5 wires are 3 for MAF and two for IAT rite? The harness comes for those connections?
Lastly any advantage to using the 85mm over the 3.5?
BTW..thanks Bob.. i'm just learning ;)
The harness does not connect the IAT. Use your existing IAT. (I recommend putting in the coupler AFTER the MAF....)
The larger MAF flows a little more than the 3.5" It is a little more sensitive to fan turbulence (idle stability) so leave the screen in.
Call Mike at Fullthrottlespeed, or ramchargers. I don't know their stock levels.
Last friday this whole section of the country had no power (don't you watch the news...?)
B
Really?.
I miss all the good stuff....
Betcha it really messed up the donut production, LOL
