I have done the search and read a lot of threads regarding this, but still cannot make the decision. I know I am on the borderline with my injectors and I want to step up. I plan to purchase a modded ECM and go bigger. Please look over my current setup and tell me which injectors I should go with.
Fresh 109 block with 206/206 cam, ported big valve iron heads, PT54 turbo, PTE remote oil system, MPE stretch big neck IC, MPE dp, Jay Jackson 62mm tb and plenum, hotwired walbro, Voltblaster, Accufab adj fpr, built 2004R trans with PTS Xtreme 3500 stall converter (9-11), boxed upper and lowers, and Eaton posi, SMC alky kit and I am currently running MSD 50's
This is in a 3500lb GN and I hope to run 10's on ET Streets.
Thanks, Bill
Thanks, Bill
