60 lb +ALKY
THensley
How fast or how much horsepower have you made ?
New combo in the coming soon and to be truthful 10.50 is my new target ET.
I did 10.50s-10.60s with mine. Factory shortblock and ported stock heads. 60s and dual nozzle Not sure the dual was needed but I did it anyway.
If memory is still in tact Grumpy & his daughter ran high 9's with single nozzle / 60's through a slic
Wow pushing "my remember" when part of my brain. I think we went in to the 10s maybe a few times with a single. Personally I'd go with twin nozzles .
I ran a 10.56, single nozzle, 6262 Ball bearing turbo. 22 psi. Champion Irons
Thanks I appreciate good info from top members ,felt I was OK
A twin novel is in the future.
I ask because I have been fulling around with Holley V6 software and it showed me running out of fuel at 5500 and 25 pounds of boost.
I’m running 80’s and alky single nozzle. Made 450hp with Tons left in terms of duty cycle
I ran consistent 10.50s-10.60 @126ish on 60s and Alky. 24lbs of boost the Duty cycles were 90%. Alky gain knob on 6 and alky box on out of the box settings. So there is still a little room at 10.50s.
Have to look at pressure.
Twins gets more in earlier
A single can flow plenty but you better have x amount of pressure.
Knobs dont tell anything
need to setup the pressure sensor and look
The nozzles are rated at x gph at 100psi
The McMaster car nozzles will flow to 500 psi making them much more than they are rated for.
Pressure is the key.
Years ago I ran 60lb injectors and 4 nozzles and 2 pumps and cleared 1000fwhp.
If your going to be lazy and not look at things get the twins its safer
I have always log pressure. And changed pump when pressure got below 140.
we run these cars meth dependent so logging ALKY and fuel is inportant
Yes my longs showed 85-90 % too, it's the Holley V6 software that confuses me.
I'll recheck my data I put in, garbage in garbage out.
I have never been found guilty of being lazy
