60lb Mototron/Siemens Low-Z Injectors & Extreme G
dlafont
Senior Member
For sale:
Mototron HiZ injectors. 300 miles on them. Injectors are a flow matched set from g-bodyparts.
$280 shipped and insured to the US. PayPal add +4%.
Extremem G chip for 60lb injectors:
92octane with alky
Stock Cam
Scanmaster 2.1 high speed data
antitheft
Will post the Extreme-G ID code and details tonight.
$85 shipped and insured.
Do injectors have original o-rings? and do these work on non modified ECM?
Please let me know, and in the meantime I'll look more into the extremeG setup. If you have info to offer, please pm me.
Thanks,
DGC
Thanks,
DGC
the injector have orignal orings im sure there damn near new. they will also work with the stock ecm since these are the high z 60's
As boost231 says...
They are pretty much brand new (O-rings are perfect).
They will work with the stock ECM.. My mistake in the description... These are Hi-Z injectors (not Low-Z) which makes them work in non-modified ECM's.
The Extreme G chip ID is GWOX7A1G
G (datastream) (inj) X (Boost/wastegate) (idle/rev limit) (theft/valet) (revision)
G - Extreme G chip
W - new high speed with IAC and Cross counts, requires Scanmaster 2.1
O - 60lb Mototron/Siemens Injector
X - Placeholder (not used)
7 - 100/95 --- Typical race setting, about 19 to 20 psi (stock wastegate)
1 - anti-theft + convenience/valet mode
G - Revision "G" (the latest revision)
This Extender Extreme G chip is intended only for use with the MAF Translator Gen-II device, which provides remote programming and control of WOT (Wide Open Throttle) Spark Advance. For setting of the Spark Advance, refer to the MAF Translator Gen-II User Manual.
Don
Interested in the 60s. Any reason you decided to get rid of them after 300 miles?
I'm sure anybody on this board can relate... Constantly upgrading... had them only for the summer. 60's were good for 11 second car but I am planning on going into the high 9's at some point so I thought I would be proactive and upgrade the fuel system as one of my first steps to keep safe.
I went with 84lb Low-Z injectors and a modded ECM I bought off the board.
Don
Ok sounds good. Well I guess there's technically still one person in front of me but I am interested so let me know...
Sorry for the confustion... Scanmaster is not being sold here... I was only describing the features of the Extreme G chip options which is what is for sale.
D
D
Oh ok, Thanks!
