62-1 Turbo
ZR1TR
I found a good deal on one of these. Just wanted to know if anyone is running it on a buick application. What are the specs. Rec stall, injectors, etc.
More About It
62-1 turbo .96 turbine p trim 62 mm compressor good for
700hp great shape.
I know I would have to go with a different housing .96 would never spool. Other than that any issues.
62-1
Just make sure it has the billet backing plate and a 360deg thrust brearing, other wise run from it.
9sec.
The guy told me it was setup for a vband on the downpipe. What exactly is that? Also what injectors, stall would you run with that size of turbo.
Sent you a E Mail.
Tell us more about your combo, if the motor has stock heads and cam then you could get by with 50# inj's if you need to buy another set get the new 60's there a nice injector, if your cam and heads are upgraded you'll need the 60's anyway.
9sec.
