6262 Turbo Limit
SCOOBY DOO
BASED CANADIAN PATRIOT!!
At what point does the CEA 6262 billet turbo run out of breath?
It hits backpressure around 70-72lbs/min. Which by the way is a lot for such a small turbo. However the combo needs to be built around the turbo to get that kind of flow out of it. Higher CR, fast ramp cam, and proper cam timing will allow the most potential. It could push a 3600lb car to very low 10's. Typical results are mid 10's @28-30psi with decent heads and small hyd roller cam in average air.
