6768 turbo ?
434nova
I know precision rates this turbo to 935 hp , but b if iy has a E cover with a 3 inch inlet and 2 inch outlet can this turbo still make the 935 or will it need a ported h cover. So my question os how much hp can be made with the small e cover. Thanks
I don't know how much power it will make, but I had a 6768 with an e cover (3x2) and I went 9.7 @ 140 at 3700lbs with a 1.5 60'. 234" engine.
Looking to put the 6768 on a 235 ci with gn1 heads and a 206 roller cam. My current turbo which is a te45a made 560 rwhp on 26 #s of boost. Found out the 6768 turbo I am looking at is a h cover 4 inch inlet 3 inch outlet. Wonder how much more power I would make over the te45a. Looking to push close to 30 #s on the bigger turbo.
Sent from my SGH-M919 using TurboBuick Mobile mobile app
My engine had gn1's also. I ran my passes with a little less than 30 psi.
You should see a decent gain switching. What exhaust housing is on it
I believe its a .85 but am waiting to find out for sure. What ar did you have. Also what size injectors were you running. Thanks
I had the 85 and used 95's
The 9.5 ptc converter works great with that turbo. I had a 17 blade which was a little tight.
Biggest thing that held my combo back was the engine was less than 8.5:1 compression.
My current turbo which is a te45a made 560 rwhp on 26 #s of boost. . Wonder how much more power I would make over the te45a. Looking to push close to 30 #s on the bigger turbo.
Why not run the 45a at 30psi before you upgrade and see what that does for you?
Im in the begining stages with this turbo. Played with it all summer and raced it .... love it!
Times in sig.
