6x9 speaker ideas
tangofox
Any ideas on how to mount a set of these speakers ? I can't return them, and really don't want to.
Also, which wires are the positve ones for the rear speakers?
Mine weren't hooked up, so I can't tell which ones are which.
ps These are the Sony Xplod, and no they aren't hot. I use to work for Sony.:eek:
I have heard that there are some adapters to mount these to a 4x10 hole. also heard they do not sound too good mounted like this. rear speakers are wired like this....LR-yellow w/brn stripe LR+ brown w/yellow stripe RR- Light blue w/yellow stripe RR+Blue w/yellow stripe.
Tango, check the car audio section, probably be more of a question for in there. There are adaptors to mount these, audiowizzard would be the man to ask to be sure tho.
Kevin
i've done this coversion in other cars, you need a spacer, something like a ring an inch high that lifts the speaker off the deck so the cone won't sit against the edges of speaker mount. Ask audio wizard:)
go to a best buy, circuit city, or local car audio shop and just tell them you need a 4x10 to 6x9 adapter for a gm g body. its a plastic spacer that offsets the speaker back a little so it'll clear the deck lid support rods. shouldn't cost more than about $10.
aaron
