Apr 19, 2011 #1 J j-6 Member Joined Jan 7, 2009 Messages 317 what you guys think about this pass leaving on 5lbs of boost 60ft. was 1.74 so I have bumped the two-step up and will be leaving on about 11-12 lbs of boost Friday night in huntsville
Apr 19, 2011 #3 R RJ REYNOLDS Member Joined Dec 16, 2003 Messages 285 That's a high MPH for a 7.28 pass. If you can get it to hook with an 11-12 psi launch you will be in the 6.90s.
Apr 19, 2011 #4 J j-6 Member Joined Jan 7, 2009 Messages 317 combo Pt61,218-212 rolla,3.5inch DP 4inch mass air flow 9.5 ptc NL
Apr 19, 2011 #5 M Mr.Spool Well-Known Member Joined Nov 6, 2006 Messages 7,346 should be good for 6.9-7.0 in the eighth,that 10 sec mph with a decent 60ft.
Apr 20, 2011 #6 J j-6 Member Joined Jan 7, 2009 Messages 317 RJ REYNOLDS said: That's a high MPH for a 7.28 pass. If you can get it to hook with an 11-12 psi launch you will be in the 6.90s. Click to expand... how much boost do you leave with
Apr 20, 2011 #7 R RJ REYNOLDS Member Joined Dec 16, 2003 Messages 285 I leave off the 2-step at 12 psi and run consistent high 1.40s to low 1.50s 60' times.
Apr 7, 2012 #8 J j-6 Member Joined Jan 7, 2009 Messages 317 RJ REYNOLDS said: I leave off the 2-step at 12 psi and run consistent high 1.40s to low 1.50s 60' times. Click to expand... I will be tickled to death to get a 1.40 consistent. That's the key consistency wins championships that's how the Bulls won them 6 rings LOL
