Originally posted by 86brick
Ted, I think we've been thru the stock crank thing before...... Believe whatever you want to believe![]()
Been a while since we talked. I didn't know if there was any "new" info out there. I guess not...
SignUp Now!Originally posted by 86brick
Originally posted by Nojug
Jack where are they, your Turbonetics people? Oh thats right Russ Merritt is he on payroll. And yes your 8.90 car is badddd your deep in the eights alright, with a pumpkin, hows your heat and A/C mine are fine, oh and whats your car weigh? If I could only manage 8.90's with that gutted fish I would burn it. I guess you will post back when you car runs with the other GN1 headed Stage II's.
Originally posted by Fuelie600
It appears we have some hard feelings between some of you guy's. I'm loosing track of who is slamming who. All those on Jacks side----RAISE YOUR HANDS. All against say--I---. Almost forgot this post was about 70mm turbos. I appreciate all the input, but please leave personal feelings to the PM's. In my book, anyone running 8-9's has my respect. All I want to know is, are the T-netics turbos built with the same level of quality/perfomance as "Limit" and or "PTE". Just wanting to make an informed purchase, not cause any salt to be poured into old wounds. Brian
Carl ,Originally posted by ijames
Cal, one thing about that gmhtp comparison always puzzled me a little - yes the GTQ made more peak hp but if you look at the hp curves they drop off fairly rapidly with the other two turbos and stay almost flat for another 1-2000 rpm with the GTQ. That has to be a big advantage on the track, and it wasn't even mentioned in the text.
Originally posted by Louie L.
Carl ,
You have noticed something that most dont. The torque is much flatter and stays up much longer with the PTE GTQ. I dont know why it wasnt mentioned, maybe oversight or just editorial decisions? Its clearly visible from P trim to GTQ to the PTE GTQ as the curve straighten outquite a bit.![]()
Originally posted by JCotton
Thats a pretty impressive response Noclue........ I mean Nojug..... or whatever you go by.I don't know where you get your information from, obviously to me, it is absolutely untrue. I've been selling Turbonetics turbos for a long time, not only to the Gn family but many others as well, they are without a doubt the toughest turbo built. I'm not going to get into what turbos fail the most often, there are enough threads here for anyone to see for themselves, do a search..................
I believe Jason Cramer ran 9.90's on a PTE 70mm P-trim. More importantly, are the comparisions between.... Brian
