72/68 Turbonetics turbo with 3 & 4 bolt housing
Loosenut
All these parts came off my car. Car made 609 HP and 709 TQ at the rear wheels. Decided to go stage 2 with the car. Parts are located in Raleigh, NC
Girdled 109, two center caps are steel, .10/.10 4340 forged crank, Molinar forged h-beam rods, diamond pistons 9 to 1 comp. .20 over Full throttle speed cam, 215-220, roll master timing set, new head studs for aluminum heads, new King rods and mains. With a cast wheel 72/68 it put down 609 to the tires at Full throttle speed shop. No other parts are included. Pick up only. I will bring this to bowling green with a deposit.Sold
TA performance mild steel headers. Coated when new and the coating is coming off. Never repaired, no cracks. Very solid headers. They look worse then they are. A little sanding and a re-coat and they'd look new., $Sold.
Turbonectics 72/68 ball bearing cast wheel turbo. Made 609 to the tires on a 233ci GN at full throttle speed last spring. Comes with a 3 bolt housing and a 4 bolt housing that belongs to this turbo. $750 OBO
