82 el camino, GN Motor
el national
I can email pictures to anyone. Silver 82 Camino from florida, No rust straight body $12,000
GN1 Aluminum Heads- Receiver Grooved
ARP Head Bolts
Comp Cams 222 Race Cam
Precision PT70-1 3 Bolt Turbo, 4 inch inlet and 3 inch outlet
55lb Injectors
Accel DFI
CAS V4 Big Neck Intercooler
Stock Intake
Stocker Manifolds
Stock Throttle Body
Billet Adjustable Fuel Regulator
ATR 3inch downpipe w/ dump
Applied Technologies External Wastegate
Sumped Gas Tank w/ -8 Braided line to the rail
XS fuel pump and filter
Don Stanley TH400 Trans w/ Reverse Manual Valve Body
Cohn Converter w/ 4000 stall
B&M Pro Stick Shifter
Front and Rear Main Seals
Volt Booster
Magna Core 10MM wires
5inch Tachometer
Boost gauge on A-pillar
Water and oil pressure gauges
Hood mounted fuel pressure gauge
AC and heat block off plate
AC delete bracket
Powder coated Valve covers and plumbing
15x4 Weld Prostars
15x8 Weld Prostars w/ 28x11.5.15 MT E/T Streets
Much More
