Came across an 82 turbo car. I have not seen it yet but owner indicates it needs a distributor coil and it does not run due to this. If I remember correctly, on a pre-electronic ignition, dont you have a distributor AND coil? Also if so, would these be the same as a N/A 231 v6 or was there somthing special for the turbo'd cars. Also what are the chances this is the only problem, or could it look like this is the problem and be somthing else?
The car is a distance away, so if I go, I would like to have a little knowledge to back me up.
