SignUp Now!what can i do to my car to make it react quicker and run faster.
stock 3.8 turbo carb
hog out the intake
port the heads
adjust your secondaries
upgrade your turbo using charlies setup
160 degree thermostat
Alcahol injection
MSD 6 BTM system
If possible advance your distributor
Shift kit
3000 stall converter
Look at the B4B website for some more recipies...
damn how much $ we talking about
Step one- Under $400
Change your oil
Boost guage
Put in some 93
Knock guage
Wideband
More advanced-
Put on a cat dump pipe
Change out the old air box, stock one is poor
3.42 rear ratio
alcjohol injection
Dont screw with the motor til its running right.
they all came with 3.42s didnt they?
I say Spend $250 on a wet nitrous kit and spray a 75 shot and call it a day. Won't beat the kick of that for the money spent, but don't listen to me.
Honestly this is the cheapest way to go. Simple and effective but make sure that you have everything running right first so you don't blow the engine.:smile:
Enough! There's lots to learn on the C/T system but you need to do the research first. A simple alky injection system and a few mods will get you more power but having the ability to put it to the pavement is another thing. The kid is right about the turbo I have posted on the board but there's more to it than that.:biggrin:
I think I've got about 5K in the parts I have now and that doesn't include the car or the time I've spent doing the research. It has taken me time to figure out how to make everything work and I'm not done yet.:biggrin: Mods to the suspension are the biggest thing here. The engine is part of the equasion but it's the combo that needs to be addressed here. Everything has to work together and can't be pieced or you will blow engines as well as spend more money than it's worth.
yes, nitrous works real good! i have the dang super powershot plate system. i might up the jets a little and see what it can do.:wink:I say Spend $250 on a wet nitrous kit and spray a 75 shot and call it a day. Won't beat the kick of that for the money spent, but don't listen to me.
...thats the last thing i need IMO... is a bottle of nitrous. something else for some a$$hole to steal from me
Enough! I think I've got about 5K in the parts I have now and that doesn't include the car or the time I've spent doing the research.
Seriously, 5K? You might want to rethink your approach. $500 ought to be plenty to get you down the track with a nice time slip. These car aren't that complicated. MNcarbturbo's list above is spot on IMO.
I've learned the first step to making them faster is to make them driveable. The best research is done on a moving car and not the interent.
whats a wideband and knockgaugeStep one- Under $400
Change your oil
Boost guage
Put in some 93
Knock guage
Wideband
More advanced-
3.42 rear ratio
alcjohol injection
