M Michael McCoy Active Member Joined May 26, 2001 Sep 7, 2011 #2 Were you the one looking for an HA longblock recently?
D dav770431 Tyler Joined Dec 18, 2010 Sep 8, 2011 #3 Ive been looking for a HA short block for a while now
T TURBOTIMMER Well-Known Member Joined Jan 5, 2002 Sep 8, 2011 #5 where are you located? I have a complete disassembled short block. id sell it cheap.
M Michael McCoy Active Member Joined May 26, 2001 Sep 8, 2011 #6 Yea I thought I spoke with you a while back.
T TURBOTIMMER Well-Known Member Joined Jan 5, 2002 Sep 9, 2011 #8 I'm in south western PA about an hour and 1/2 from Cumberland. Motor was rebuilt and for some reason I took it apart. Pretty sure it's STD bore. Crank is .030/.030. $150 for block and rotating assy if you wanna make the trip. Tim
D dav770431 Tyler Joined Dec 18, 2010 Sep 11, 2011 #9 its an 84-85 HA block? And it just needs to be assembled?
T TURBOTIMMER Well-Known Member Joined Jan 5, 2002 Sep 11, 2011 #10 It will need cleaned up. Been sitting apart for 2 years.
T TURBOTIMMER Well-Known Member Joined Jan 5, 2002 Sep 11, 2011 #11 Yes, it is a hot air motor. Not sure which year, but it 84-85. I'll give you the 8445 heads off it, too. Just want someone to use this stuff.
