EyeTalk2Trees
- May 29, 2001
I've had mine changed over, I had conely do it last year, its been working fine, Now I've changed the cam and bunch of stuff I'm putting it together and I'm having a problem connecting the harness back. THe two large plugs from the FI harness go to the ecm (The three wire, and the Four wire connectors)? Also the two connectors comming from the ECM they go to the cam and crank sensor? THis is how i have it, I don't want to start it for fear of messing somehting up,
IS there something you skip when you have the conversion???
this is all i'm stuck on and the can handle the rest
