84 hot air question
jimmysgbody
Does anyone have good detailed photos of where you tapped in for an oil pressure sender and a temp sender under the hood I would like to install aftermarket gauges also I attached a photo of what I believe to be the factory temp sender not in the best shape anyone have a suggestion on a source to get a replacement the connections are pretty corroded
I tapped into the oil supply feed line to the Turbo at the 90 degree elbow using a 1/8" female inverted flare to 1/8" male NPT adapter & replaced the elbo with a "T". From there I ran a 32" 3-AN Braided Turbo Oil Feed Line 90 Degree to Straight to the driver side fender for the gauge sensor.
Read this thread: Coolant Temperature Sensor / Engine Coolant Sensor
I can't tell from your pic .... is the Temp Sensor have the mushroom top?
