TURBOPOWERED68
David
- Jan 31, 2006
i can't remember 100%
but i think i used the Monte's OE fuel lines.
SignUp Now!If you mean hot wires as 12V positive, then YES, if you mean Hot wires like ones off the alternator, then no.
You need to run a 12v ignition positive to the injector harness (pink wire/black stripe) or your injectors will not work.
If you are using the factory harness for the electric fans, you will need to get 12V to the brown wires on the relays for the fans on the drivers side.
You also have to hook the orange wire up to the battery from the ECM, that is the main power for the ecm.
Thats all I can think of at the moment..
