my 84 non turbo Regal started running bad today at idle. checked plugs and #2 was gas fouled so I changed it and it Fouled it again. so I checked compression and it has none. I can also her a popping noise coming from carb when I give it gas. I pulled valve cover to make sure rocker arms were moving as normal and they were.
So whats the next step valve spring change out or pull head?
thanks for any help.
