Okay guys, I give up. I am really frustrated. I can't even get the darn thing to idle. Here is a turbolink file of the 20 seconds I could get it to run. (right click on link and select 'save as') http://www.skiboathelp.com/art_84gn.ecm Maybe someone can see something I missed. The car is a completely stock 84 GN, It started running like crap all of the sudden one day when I went to go move it. The car is currently undergoing an interior restoration, so lately it only gets started about every other week. I checked the plugs, four were fouled. I replaced the plugs and wires, and they fouled again, car wouldn't run. I checked fuel pressure, steady at 30lbs static. I did a leak down test, lost only 2lbs after four hours. I replaced the coil pack and plugs, again same results. I then upgraded to the 87 CCCI module (the 84 was too pricey), replaced plugs, same results again. I then installed a known good set of used injectors, replaced plugs (parts guy is starting to wonder where all those plugs are going!). Same results, won't run and plugs fouled or wet. Other things that have been replaced recently: O2 sensor, MAF hose, all vacuum hoses, PCV, fuel filter. Any suggestions on what to try next are GREATLY welcome! Preferably, before I drag the car with the tractor out to the back fourty into the weeds.
