85 200R4 build up suggestions?
fullahotair
Hi guys, finally after 2.5 years of waiting for my WH1 to get painted it is painted and now i am back in the grind of things. Here is the scoop, its an 85 GN tranny and it has 80K on it and it works fine. I am doing an IC conversion more or less, and it should be making some respectable power (i hope), but i don't expect it to be pulling the tires off the ground or anything like that...
I have a higher stahl converter to put in it from Pats (slightly over stock - i forget the stahl since, i'll have to look it up) . I am debating if i should have it "freshened up" or if there are some key parts to get upgraded. So if you have a suggestion, I would like to hear it.
Thanks,
Nathyn
a properly engineered recalibration kit and stator tube should be all you need if the trans is in good condition.our manual will be helpful if you decide to do it yourself.www.CKPerformance.com
Do you offer these items you speak of or do you have a manufacturer or choice? PM if you have any prices...
Thanks,
Nathyn
