Sweetblack85
High Powered
- Mar 24, 2014
1985 Buick grand national turbo 3.8 Engine build: new comp springs, heads lightly ported, arp head bolts, felpro gasket upgraded turbo, upgraded intake pipe, ported throttle body (egr block off plates done the right way) after market boost valve, ported intake, new 100amp powermaster alt, new timing chain and damper, new upgraded timing chain cover and oil pump, all new sensors, new front and rear seals no rope, new stainless steel headers still in box, new starter, new poly motor mounts, always ran amsoil oil high zinc, new lifters, new maf translator for lt1 maf sensor, msd wires 87 coil pack with hot wire loom, billet fuel pressure regulator, 87 ecu with custom chip, k&n long cone air filter with cold pipe, 42# injectors, scanmaster and more!
The bad it needs cam bearings from running a hv oil pump.
Transmission recently rebuilt original gn 2004r have receipts new 3000 stall converter new mount
Will throw in the rear end with disk brake upgrade if you pay asking price new posi center section redline oil, axle bearings seals, cross pin shims, rotors.
Selling because I'm going LS. Will not part out $2000 if interested text or call (352) 256-1192 Gainesville Florida
