85 Coil pack & module
Convert it over to the 87 setup. I have a almost new coil module and adapter plate.. jist order the wiring harness from caspers. You don't want a factory unit..
Converter it over to the 87 setup. I have a almost new coil module and adapter plate.. jist order the wiring harness from caspers. You don't want a factory unit..
Is it "plug & play"? Around how much does it run? I'm interested
You will want the hotwire harness imop
http://www.gbodyparts.com/product_i...=1716&osCsid=277f253727a463946656cd43d1a6b73c
If you want to go cheaper but for the price point I wouldnt
http://www.gbodyparts.com/product_info.php?manufacturers_id=35&products_id=1301
I have this
http://www.gbodyparts.com/product_info.php?manufacturers_id=35&products_id=783
I have this
http://www.highwaystars.net/coil-pack-acdelco-12353801/
And this as well
http://www.highwaystars.net/module-ignition-control-acdelco-replaces-24503624/
So for the coil, module, adapter plate ill do 240 shipped to you. All you'll need is the hotwire or adapter to make it all plug and play
Are gaskets included?
I have this
I have this
And this as well
The gasket between the coil and module is there.
Here is the adapter plate
No.. bolts right to the bottom of new module and right to the factory bracket.. Only gasket is between the coil and module which is installed already.. I'll send you everything you just need hotwire.. not sure where I have mine or I would sell that to you as well
Great. Thanks for your help.
Anytime. If you need more help fill free to text me. 520.248.0793
Brent
I have a training class all day tomorrow or I would send it then. It will go out first thing thursday. Text me or pm me your address
