85 hot start problems
mongoosetoo
I assume I have an injector problem. With my fuel pressure guage hooked up, when I turn the car off I can watch the guage go down pretty quickly. I assume there is a leaking or not working injector.
The performance of the car has always been hit or miss. And when I start it, it always sends up a smoke signal of fuel vapor. I reckon that's the unused fuel leaking into the intake/piston after I shut off.
Does this sound like injectors? Where do I get refurb or new ones? Thanks, brew
o dear god. anyways i think its a stuck injector. i had this problem when one of my wires came out of the ecm and was grounded out causing the injector to stay wide open and when it would run it would be a fuel smoke cloud. i would not run the car till you get this fixed. send the injectors off and have them flowed and cleaned codymotorsports is where i sent mine. or get a new set of injectors. if its not that check all the wires to the ecm. you can also pull the plugs to see if there is raw fuel on one or more of them.
