ILLEGAL REGAL™
- Nov 27, 2004
10pt cage, front half moly rear 6pt is ms- total chassis work cost $4000
parachute mount/release -cost $350
window net -cost $100
trz rack -cost $500
trz adjustable upper and lower a-arms / QA1 coilovers -cost $1500
wolfe racecraft double adjustable uppers and lowers w/spherical bushings and CE 3-ways
wolfe anti-roll bar -cost $800 for rear suspension
12bolt rear w/spool and 4:56's and moser axles
plastic race buckets w/vinyl covers
3 phantom guages in pass side
manual doors
rear factory seat
6" extended pin-on cowl (VFN custom made) total w/paint was $1000
10gallon cell in trunk
battery in trunk
sbc mounts welded to frame
28/10.50 on rear with holsehots.. frame notched
26" et fronts on holeshots -rims/tires cost $1450
exceptionally clean body and chassis, only bad spots are the bottoms of doors but can be fixed.
also includes a griffin polished aluminum radiator
brand new polished Ed Quay aluminum pro wing -cost $250
85 grill(has an 87 on it)
stock steel hood
and any other pieces for the car I'm forgetting
It needs:
windshield- it had a crack and when it was pulled for the cage it busted
parachute
fuel pump/lines etc
motor/trans
ignition
shifter
tach
harness is out of date
all the cage work is 3 weeks old, majority of the other chassis work is about a year old, all suspension is new, rims and tires too.
also if you needed them I'll give you the $1500 stainless stepped headers for a sbc w/spreadport heads using motor mounts- they fit mint! For a small additional fee
$6500 FIRM
here's a bunch of pics
http://www.cardomain.com/ride/743472
trz rack -cost $500
manual doors
rear factory seat
battery in trunk
stock steel hood
It needs:
parachute
fuel pump/lines etc
motor/trans
ignition
shifter
tach
$6500 FIRM
