Boy Buick85
- Apr 9, 2006
I am selling my 85 T-Type Gray on Gray Here is my Number 713-584-5680 please call after nine Ask for Vincent
TRW Forger 30 over pistons
Ported and Polished Heads
Ported and Polished Intake
009 Injectors, 42 pound
Billet Adjustable Fuel Pressure Regulator
Hot Wire Kit
Walboro 340 Fuel Pump 206/206 Webber Cam
Billet double roller timing chain
New Comp Cam valve springs
Upgraded Turbo (flows similar to a TA49) 800 cfm
Custom Lee Thompson 3" Down pipe
3" Stainless ATR Single Shot exhaust
Turbonetics Deltagate
Turbonetics In-Car Adjustable Boost Regulator
Big Mouth Cold Air Intake
LS1 Maf
87 ECM
Turbotweak Chip, additional Red Armstrong Chip
Turbo Pre-Luber
2 Huge oil coolers(trans/engine) with electric fans(fans arent hooked up)
Autometer Oil Pressure and Boost Pressure Gauges
PTE Oil Filter Relocator
Polyeurethane Trans and Engine(both sides) mounts
PTS Aluminum Transmission pan(additional 2.5 quarts)
PTS Shift Kit
PTS Transmission Pressure Regulator
Many A/N fittings and Push Lock hose
Scan Master
S10 wheel cylinders with Brake kit
aluminum Drums
Remanufactured Master cylinder
BRAND NEW STARTER less than 200 miles on it
The engine, transmission, and turbo have been rebuilt 10k miles ago, so everything is fresh!
The car is fast and strong, runs great, it has not been tuned on a dyno yet so i have not turned the boost up.
the interior of the car is in excellent condition, it has never been smoked in, there are some stains on the carpet and a small crack on the dash(around the defrost vents)
the car could use new paint like most any car this old, it still looks good but the clear coat has been coming off of the roof of the car, there are no dings in the car, the driver side front fender is damaged and i think should be replaced, this car has NEVER been in a wreck, the damaged fender is from the wheel coming off on the highway and the car falling on it. and the bumper fillers have broken away. Since then i have had the dent pulled out but the bondo needs to be sanded down, I also should have fillers on the car by Saturday Hopefully .
The Ac has been pulled out but i have all the parts in case buyer wants to put back in.
ASKING $5600
http://i117.photobucket.com/albums/o...gman/85_12.jpg
http://i117.photobucket.com/albums/o...gman/82_12.jpg
http://i117.photobucket.com/albums/o...gman/80_12.jpg
http://i117.photobucket.com/albums/o...gman/75_12.jpg
http://i117.photobucket.com/albums/o...gman/70_12.jpg
http://i117.photobucket.com/albums/o...gman/68_12.jpg
http://i117.photobucket.com/albums/o...gman/63_12.jpg
http://i117.photobucket.com/albums/o...gman/48_12.jpg
http://i117.photobucket.com/albums/o...gman/56_12.jpg
http://i117.photobucket.com/albums/o...gman/20_12.jpg
http://i117.photobucket.com/albums/o...gman/9d_12.jpg
http://i117.photobucket.com/albums/o...gman/8b_12.jpg
http://i117.photobucket.com/albums/o...gman/1e_12.jpg
http://i117.photobucket.com/albums/o...gman/7d_12.jpg
http://i117.photobucket.com/albums/o...gman/7e_12.jpg
http://i117.photobucket.com/albums/o...gman/5a_12.jpg
http://i117.photobucket.com/albums/o...gman/3e_12.jpg
http://i117.photobucket.com/albums/o...gman/3a_12.jpg
Hot Wire Kit
LS1 Maf
87 ECM
Turbo Pre-Luber
PTS Shift Kit
Scan Master
aluminum Drums
ASKING $5600
