Balancer 86/87 stock 125.00 (have 2)
J hook for turbo powder coated black 30.00
Rear alternator brace powder coated black 30.00 (have 2)
Oil dipstick and tube 60.00
Accessory bracket no stripped holes 75.00
Intake manifold stock 100.00
Stock plenum w/TB gasket 35.00
TTA billet vacuum block with hardlines 125.00
Modded ecm for low imp injectors 150.00
Lower crank pulley 25.00
IC fan stock 30.00
PC16 Standard CAM sensor new unused 125.00
Coilpack IGN tester and plug wire tester Caspers 90.00
Caspers Injector Harness Hot Wired w/relay 75.00
Braided turbo drain tube 40.00
CB1398 bearings std for 6 cylinders NEW not used 50.00
Reed 210/205 hyd flat tappet cam used 30.00
Items above are plus shipping.
IC fan stock 30.00
