86-87 Engine Sensors and "assembly manual"
montecarlofast
740 ftlb Rocket Couch
I am looking for a full set of engine sensors off of a 86 or 87 Intercooled T Type or GN as well as A "Assenbly manual" That i have heard was offered for the 86-86 turbo cars. Thanks
save your money on the assembly manual
Engine Description Manual
for sensors i would hit a junk yard and find a buick powered 85-87 fwd for these
iac
hi fan temp switch (for hi fan above 224*)
coolant overheat switch (for overheat idiot light but most discard for a real coolant gauge)
coolant temp sensor (for ecm)
egr solenoid (if running an egr)
bosch ..xx233 fuel pressure regulator (you might even find a ..xx237 which has slight higher base fp)
you might get lucky and score a magnavox coilpack and module , even if the module isnt correct the coilpack will work
86 fwd like the cutlass cierra and lesabres with buick engine even came with the turbo correct 1227148 ecms
youll need these turbo specific and arent cheap
combination oil pressure idiot /fuel pump secondary switch (most remove for oil sender for aftermarket oil pressure gauge )
tps
crank sensor (and bracket)
cam sensor complete w/cap
wastegate solenoid (most use a manual boost controller so its not really needed)
knock sensor
egr valve
maf sensor (i would get a translator and find an lt1 3"or ls1 3.5"or zo6 4" in the yards as many gms had them including fwds and 4.3astro vans )
