86/87 upper rad hose reroute ?
The offset pipe fit well, but is tight. You might have to use a small pick or screwdriver to help guide the hose end over the radiator outlet. Maybe there's a little more room if you have a stock radiator...I'm running an aluminum b-cool unit. View attachment 389095
Did yours seem like it was going to hit the up pipe. I have the same one but mucking it up it don’t look like it’ll fit
Nope, plenty of room to clear the up pipe on mine, but this could differ on others that have a different up pipe bend/direction.
I ended up cutting about 1” off this pipe for the SLIC (closest to the radiator) and having it re-flared in order to be able to connect to the rad easier
Sorry, that hose is a really tight fit, and the 2 little hoses have to go on the metal hose all the way down then slide it onto the radiator and water outlet, silicon spray makes the job easier
