86 bonneville parts
No Tie
I am getting a 86 bonneville 4 dr, low mileage smooth quiet 3.8 na motor.
Any suggestions on other useable parts before I scrap out the body.This
is a real granny car.
Thank you for the reply. Its a N/A 3.8 #109 block w/ 61K MILES. 200C TRANS. Old miss.Gormans car . It is too bad to can the body but I have
little extra space for a sleeper project.
The torque convertors interchange between a 200C and the 200-4R too. Double check the trans model. I pull 109 blocks all of the time and they are usually 250C/350C trannys.Hows the underbody look? If the suspension is clean those parts also might be worth keeping. Its always handy to have a spare set of control arms if you do the poly bushing upgrade. Door hinges are also worth keeping.
