Heads 1.77 1.50 ss. ferrea valves
ported and polished. intake and ext
header matched !! 5 angle valve job
100lb springs .poly seals. EGR ports filled
ported lower
70 mm t.body & upper intake
d.roller timming chain. and button
ARP head bolts
bullit v.block
EGR block off
champ valve covers , breathers
under drive pully
poly motor mount
short block all orig never been removed 47k miles
Razors Alky injection kit
TRANS
200r4 brf factory trans w.stage 1 shift kit
3400 lockup 10"
trans cooler
H.D u joints
poly trans mount
REAR
8.5 posi 3.42 gear
eaton center section
seals , bearings , ARP 2.5" wheel studs
Soft shoes . s10 cylinders, hardwear kit
SUSPENSION
H&R upper and lowers
kyb f&r shocks
new moog front and rear springs(cargo in rear)
poly sway bar bushings
poly rear housing bushings
front pads and calipers
FUEL
60lb injectors
walbro 340 pump
hot wire kit
INTAKE & EXHAUST
super extreme front mount
3" down pipe w/46mm gate
3" SS cat back
Kenny Bell Headers S.S.
3" flow tube
3 1/2" maf tube
3 1/2" LS1 maf
4" K&N filter
PT5469 w/.82 housing
COOLING
f.body rad
ramcharger duel fans
scanmaster 2.1
pro fec b boost controller
PLX wide band
oil , tach and boost gauges
GEN 2 w/extreme G chip
PAINT
stripped to metal
int removed 3base 3clear
glass fillers.
all soft seal weather stripping
4 front GTA striped
painted color of the car base clear high heat
polished lips
tires
225/60/16 fronts
295/50/16 rears (mickey thompson drags )
car is perfect in and out call 856-340-3696
