Very original. I am the second owner. Car came from Ohio. Car just sits in garage and goes to car shows. Tired of winning trophies, needs a new home. Original paint, no rust (I used POR15 on rear axel), T-tops with no rust underneath, battery and muffler were replaced by first owner. I replaced the accumulator ball and put new Kumho tires on it (they have a couple thousand miles at most). I also installed a hot wire to fuel pump. Paint is very shiny but there is some spider cracking on hood. Original black shocks, springs. I even have original numbered spark plug wires! Original 9 hole hood insulator and computer chip. There appears to be a small vacuum leak at rear of intake manifold, as that is where the smoke leaked out when I checked it for leaks. T-tops don't leak but a little water drips in rear window when I wash it.
A/C doesn't blow cold but all parts are there. I can send more photos upon request. No disappointments here. Asking $22,500 OBO. Located in Champaign, IL about 2.5 hours south of Chicago.
