86 GN for sale $25,000
jimmag
stock displacement 109 block,Forged rotating assembly,RJC girdle,Comp Cams 212/212 hydraulic roller,RJC deep oil pan,Champion ported irons,130lb valve springs,RJC Bullit Proof head gaskets, T&D roller rockers, Motor built by Carlquist Competition Engines, Oakville Ct ARP Studs and bolts, RJC rear motor brace, TA headers coated in and out and wrapped, GN1 stainless 3"dual exhaust, Precision 69 lb injectors, Precision 67 mm ball bearing turbo,TR Custom Parts Canton oil filter and turbo saver, Walbro dual 240 gpm fuel pumps, Champion 70 mm throttle body on a Champion doghouse and intake, RJC Power Plate, TR Custom Parts Big Mouth Cold Air, Meziere 55 gpm electric water pump, Billet Aluminum Pulleys, C/K billet trans parts set up by Otto, Driveshaft Shop aluminum driveshaft, 3.73 Eaton Posi Unit, front sway bar removed, Calvert 90/10 front shocks , stock springs,Calvert adjustable rear shocks, stock springs, H&R PartsNstuff Super Sway Bar, H&R PartsN stuff adjustable upper control arms, H&R PartsNstuff poly transmission and crossmember mounts, Mickey Thompson 275/60x15 drag radials.
XFI/FAST ecu.
Best time to date 9.98 @137 mph .JimsGN
2014 C-7 Corvette on order expected delivery date 10/1/13 Wife says sell GN or move into it when Corvette arrives.Jim Maguire Newtown Ct 203-996-8450 or jimmaguire@jpmaguire.com
pictures posted tomorrow
